Results 1 to 10 of 17
Thread: Anyone had major issues with 3.6TDV8
    Oct 2011
    Sunshine Coast
    Hi just a general query. I have a 3.6TDV8 in a 2010 RRS and have noticed on RRSport forum that some of the guys have started to have some major failures with this engine. While this was on the RRSport Forum, the same engine is in the FF. Anyone know if this is isolated or is this engine getting history/reputation for major failure as it gets older? Mine has 45000Km on it I had to had one turbo repaired due to siezed rod that alters the geometry. However, some in UK are reporting complete and major engine failure, with LR unable to supply replacement exchange motors in timely manner due to lack of supply of cores. Hope this is isolated cases only!
    Mar 2007
    I haven't heard of anything ! FFRR has no more than alternators and some broken exhaust manifold studs; and high mileage units seem only need to replace suspension bushes. The only BIG reminder is to have the auto flushed and filter replaced at 60k - 80k depending on use. Same old story oil and filter need to be changed or the grit starts trouble in the T/C, a few here on the D3 forum have had boxes replaced after T/C failure on higher mileage autos.
    Dec 2009
    Tyrendarra Vic (South West Vic )
    A bloke I spoke to a few days ago told me his uncle had to replace a turbo on a 2009 model. Dont know if its a problem and I dont have any more info on this fault. Sorry
    Gary
    Oct 2011
    Sunshine Coast
    Thanks. I changed the oil on the tranny at 43000km fitted the metal pan. Plus have changed diff/transfer case oils. However the failure on the forum in UK was fairly substantial (seized engine) issue the owner was having was lack of availablity of replacement engines from LR. The question being asked was a) was this because it was so rare? or b) was this because it was common, and all replacements had been used? Of course we all hope it was a)! If you have a read of thread "not so bullet proof TDV8" on RRSport.co.uk you will get better idea.
    Aug 2010
    Sunbury, VIC
    The guy I work with has one in his 2010 RRS with 95KKM on it now, all without issue. I would think if it makes it that far that it wouldn't suffer a major failure now... Hope they are isolated cases, they are an awesome engine.
    Mar 2007
    I have just read that article in the RRSport forum, very interesting. My initial thoughts were after the first turbo failure some metal or other contaminate might have got in the system which led to the later failure. Will have to wait to hear of the cause when that engine is stripped. Bad fuel or even bio-diesel in these motors will/can cause catastrophic failures, all makes with these hi-tech engines are in the same boat. Australia is one of only a few countries that legislate the quality of fuels to be sold to the public
    A quick search on FFRR found only 2 complete turbo failures with only one having to have a head removed to find some metal from the turbo. I wonder if the engine compartment and the twin turbo setup is to blame. To remove the RH turbo in the Sport you have to lift the body so I thinks airflow and cooling has to be restricted if space is that confined.
    My other thoughts come back to the dreaded EGR setup, all that crap being recirculated can't help the engine or the oil, given that oil is the blood that keeps things spinning, especially when using 2 turbo's in the Sports confined engine space, and those turbo oil lines aren't that big. ( think cholesterol in the arteries )
    I have a BIG preference for inline 6 cylinder diesels , that's why the Td6 is so appealing more room, better cooling, longevity and extremely reliable. And much more tolerant to fuel quality. If we can get the auto problems sorted I would fit a variable vane turbo and re-chip the engine for a comfortable and reliable 250 hp and 420ft/lbs of torque, higher power is available but torque figures drop off !!!
    Now back to finding the auto solution !!!
    Laurie
    I suppose the easy way to find out about engine availability; would be to ask a LR spares dept the cost and availability of a crate motor ?
    Laurie
    Aug 2010
    Sunbury, VIC
    Quote Originally Posted by Laurie View Post
    to remove the RH turbo in the Sport you have to lift the body
    Remember that this is not a big deal or a long job if you have a hoist. Was done the Stealers a couple of weeks ago, and there was 2 sports and a D4 with the body off sitting to the side of the hoist. I asked the workshop manager about how many jobs they did that for, and his relpy was a heap as it is a doddle to work on with the body out of the way.
    Takes about 25 minutes to pull it off - it is designed that way.
    Cheers - Gav
    sheerluck Guest
    And if you haven't got a hoist......you need to be the size of Tom Thumb to get to where you need to.
    Mar 2007
    Thanks Gav I would have thought at least a few hours.
    Is the turbo layout or ancillaries different on the RR Sport to the L322 ? Their failure rate seems to indicate there certainly is something majorly different !
    Laurie
    Aug 2010
    Sunbury, VIC
    Quote Originally Posted by sheerluck View Post
    Yeah, and magic spanners that can just appear on the nuts...
    Laurie
    Not sure, But as you can't pull the body off an L322 there must be some way of getting to them...?
