Don't know off hand, but you could take a look at the following link:
eBay Australia: Buy new & used fashion, electronics & home d
--AJ
Hi
anyone know what size and thread they are please?
2007 Discovery 3 SE7 TDV6 2.7
2012 SZ Territory TX 2.7 TDCi
--AJ
yeah, i saw that but they don't give you the size of them
want to use allen screws as i find the slotted heads are a royal pain with an overdrive fitted ...
and want to get them so i only have to crawl under it once
Hi Inc.
I kno where you're coming from with crawling under it only once. I have sent off an inquiry to the seller as to the thread type and diameter (they cant' shoot you for asking) If they answer I'll post it here. Allen screws if available would be a better option for the speedo cable fixings.
AJ![]()
3/16" by the look of the ones I have here - fairly coarse thread - looks to be 30 or 32 tpi on the gauge but it's a bit dark here - can't really tell which it is
and the answer is
apparently they are 2BA 1/4" long
You will find 2BA and 3/16 BSF are interchangable.
