                                                19th March 2013, 08:07 PM
			 How to replace a manifold stud How to replace a manifold stud
					Hi all
 The squeal wasn't the belt its the front manifold stud.
 It has broken.
 Just wondering how easy it is to replace.
 Should i replace all the studs while I'm at it our just the front & rear one?
 Do i need to replace the gasket also if there is one?
 Is it a big job that needs a mechanic or can i have a go at it easy enough?
 Mick
                                                19th March 2013, 08:40 PM
					Micka i had mine go couple of years ago i just took it to an exhaust place wasn't too much including machining . Got mine done locally let me know if you want to know where . Good luck . ( ps when we heading out again
 ? ) Richo
                                                19th March 2013, 09:08 PM
					Hi Richo
 Yeah I might give Sunbury exhaust a call.
 Mate hanging for a drive.
 As soon as the cars fixed.
 I'll get it done next week.
 I'll call ya.
 Toolangi I reckon
                                                19th March 2013, 10:07 PM
                                                #4
					Is it. TD5?
 If so then it is likely the manifold has warped, it may need machining.  Fix the problem long term. From what I remember (and the info is on here somewhere), drill out the holes on the manifold to 10(?) mm and have the webbing slotted. That should prevent any future warping.
 Ian.
                                                19th March 2013, 10:15 PM
                                                #5
					Thanks for that.
 Sounds like a job for an exhaust pro.
