Results 1 to 10 of 13
Thread: Puma sway bar 'inspection'
    Aug 2012
    Robin Falls
    Hi Folks
    So I have just been called by Land Rover Australia. They want me to take Hector into Darwin for a hoist and underbody inspection as soon as possible. When I asked why, the fella was kind of unspecific, but said they needed to check the sway bars.
    Now must admit I've never actually noticed if any are fitted on Hector (MY2012 110 HCPU). Hector spends most of his time hauling loads through the rough so wouldn't want 'em anyway.
    Anybody else had this call- perhaps those with new 'heavy duty' suspension hardtops, HPCU's or 130's? Whats it about?
    Alan
    Nov 2012
    Maybe there's been a number if failures recently - the RH bolt on my front sway bar removed itself recently (a VERY loud thunk was heard under my feet whilst driving at 100km/h) This is a MY11 130 HCPU
    It was replaced quickly at the dealer shortly after that (4 weeks ago)
    '11 Def 130 "Henry"
    Apr 2010
    Connolly, WA
    Hi Alan
    There was a long (and sometimes heated) discussion about sway bars/ anti roll bars a couple weeks ago.
    A number of people were of the opinion that they aren't really unnecessary and a number of people felt they are actually required for the safe use of the car.
    Please post feedback on LRA's actions and why they might be snapping mounting bolts (if that's the case!). That would sound like a lot of strain and movement...
    On a separate issue, you appear to be on a very short list of people who actually received a call from LRA for a potential recall. Must be a pretty serious concern to them...
    Lou
    Feb 2009
    No special treatment for me as yet, mines 2010 though.
    Jason
    2010 130 TDCi
    Oct 2008
    The TD5 Extremes for MY03 had no sway bars from the factory. I've got one of these and a new PUMA with sway bars. The TD5 off road is slightly less likely to lift a wheel. The PUMA has better traction control so the difference is not much. On the road, the PUMA gives the illusion of better handling, but will nor corner any faster. So IMHO its' an extra piece of crap to break but does make those who don't want to compensate for a sloppy vehicle happier.
    I personally subscribe to the teachings of the original range rover. Sloppy springs at each end , a load leveler in the middle, and the feeling that you will scrape the mirrors on the road around roundabouts, BUT amazing soft and comfortable off road.
    Jun 2007
    Margaret River
    My puma 130 my12 had the sway bar disconnect
    Only noticed when I found bushes on the driveway, which promped a good look underneath.
    I'm guessing this is a common fault.
    It has the potential to foul the steering when it drops out
    Nov 2012
    Quote Originally Posted by Loubrey View Post
    Hi Alan
    Mine didn't snap, just came loose and fell off. I did notice increased body roll when it wasn't attached.
    '11 Def 130 "Henry"
    Jun 2007
    Margaret River
    That's the same as mine, no snapping, but the nut securing the short swivel jointed section came loose and swung down onto the steering rod
    chook73 Guest
    Same thing happened with mine, a 2009 110 wagon.
    Somewhere on the 'net all recalls are listed.. Lost the link.
    I'd suggest Google it. If it's not a recall I'd be asking why this couldn't wait until next service.
    Max P
