Results 1 to 8 of 8
Thread: Cost Effective Maintenance for TD5
    Expedition 130 Guest
    Smile Cost Effective Maintenance for TD5
    Anyone with a TD5 using the FTC Decarbonizer or Flushing Oil concentrate from Cost Effective Maintenance? If so is it recommended or any problems.
    Also their other products, AW10 Antiwear and Cleanpower Fuel Treatment?
    Greg
    no requirement....
    use a good synthetic oil in the engine, change it and the filters every 10K Km.
    NSW far north coast
    no requirement....
    What he said.
    schuy1 Guest
    What they both said CEM is only for toyotas, Unless you feel you have to belong................
    Apr 2002
    Godwin Beach 4511
    32.38 MB
    hmmmmmmmm
    oddly enough, i am going to beg to differ.
    it has been my experience that if you only lightly use your turbo diesel then CEM FTC Decarboniser has something to offer you
    if you regularly haul heavy loads you will see little benefit from it.
    revving the crap out of it makes no difference if there is no strain on the engine.
    if you rarely pull a heavy load for a sustained period or spend a fair amount of time in city traffic each day then FTC Decarboniser will make your turbo diesel run better, it did to several of mine.
    and the effect was the same as hauling a decent load for 2 or 3 hours.
    smoother running and a sweeter sounding motor..
    the oil flush would be a waste of time on a td5 unless it has done some pretty serious mileage.
    2007 Discovery 3 SE7 TDV6 2.7
    2012 SZ Territory TX 2.7 TDCi
    Jun 2011
    Berowra Heights NSW
    Quote Originally Posted by incisor View Post
    hmmmmmmmm
    Agree, I was also under the impression the harder a diesel works, ie pulling weight, not hi revving the cleaner they run and less carbon build up in the valves, head and oil, after all that is one of the main uses for a Diesel engine moving heavy loads , that is why they have a hi torque output with low revs compared to a petrol engine.
    Jan 2009
    Kuranda, Far North Queensland
    Hmmm. Could this be the cause of my intermittent loss of torque at low revs?
    I see this stuff is $120 per litre. How much do you need to use? And how often?
    Howard
    Quote Originally Posted by Greyfox View Post
    Apr 2002
    Godwin Beach 4511
    32.38 MB
    you use only a few ml per tank full
    (mix rate1:1600, double dose first tank)
    i use it in my 1959 sii petrol and i use it in my 2010 vw diesel with dpf
