Hi Bob,
Very tidy looking little unit with low km's for the year! Is it a South African import (km instead of miles) or did they sell 90's in NZ in 2008?
Those General Grabbers are actually quite remarkable on performance. Really quiet and smooth on the road and superb on rocks and sand. They do clog a bit in the mud, but you can't have everything. You might be waiting for a while to change them as well though as they are good for around 80,000km's depending on used.
The main thing on a Puma IMO is protecting the underside. Devon 4x4 in the UK Shop Online does a transmission guard as well as a protective housing for the fuel cooler, both slightly vulnerable, especially on rocks and areas where logs or branches can knock up into the underside. While you're at it you might as well throw in for a Mantec steering guards and snorkel (if those are scarce in NZ). You would be surprised at how little freight would be on those 4 items!
Unless you want to exceed the 90's listed load capacity, the standard suspension is fine.
From personal research the best power upgrades appear to be BAS and Alive tuning systems. They both do the upgrades over the internet and e-mail with multiple "maps" depending on your requirements and the reports here on the forum is really good.
I would hold off on the barwork and winch mountings until you've felt the 90 capabilities. I have in 3 years only needed my winch 4 times and every one of those was to recover a non-Land Rover in the driving group. Without wanting to invoke ill luck on myself, the 90 is very difficult to get stuck...
There are lots of bits and do-hahs you can add to personalise and cosmetically enhance the car, but again I would trawl the UK websites as their service is mostly very good and I've only had professional service of the likes of Devon 4x4.
Hope this is the sort of opinion you're after and good luck with the buy!
Lou
