Results 1 to 10 of 38
Thread: Solar power 3kw system
    Hi all,
    Just got a quote for $7000 for a 10 panel system, 2.5kw system, fully installed.
    Is this a good price, what should i be looking out for to get the best deal? Living in west ryde, sydney.
    Mar 2012
    Armstrong Creek, Qld
    I've got a few rellies & friends with solar & they've all gone for 5kw as apparently it's the minimum output to really make a difference. Don't quote me on that as I don't have it!
    d@rk51d3 Guest
    Re: Solar power 3kw system
    Probably depends on your usage.
    Mum & Dad recently had a 3kw system installed, and its pretty much wiped out their power bill so far.
    $7000 pre rebates is average for a 3kw system.
    Oct 2008
    bacchus marsh
    how much are you getting back per kilowatt
    Gosnells
    Go for as big as you can afford, try and arrange panels to get the best winter/autumn/spring aspect, as summer will look after itself... "losing" a bit of summer light does'nt hurt as there is plenty.
    You'll "never'' add the extra panels on afterwards.- Human nature.
    Mine is 3.6kW, 3 strings available, facing 045 (NE) degrees on 18 degrees slope. Power bill gone. - But good quality panels...
    I could do with another 500 to 1kW facing NW or even W., lifted up to 30 to 40 degrees to harvest the 'after 3pm' sun. - Virtually dead in winter, idling at a few hundred watts in summer!
    Scarborough QLD
    I have a 3KW system installed and am getting the 44c per KWH. On my last bill they paid me $279!! We do not have air conditioning and there are only two of us. When I had it installed I was quite happy with doing away with my electric bill. The fact that I am getting money back is a bonus.
    The system cost $4000 to be installed and we are generating over 300KWH per month.
    Ivan
    Aug 2010
    Sunbury, VIC
    A quick question - is there a lot of Solar already in your street? If so, I would chack your voltage one day - mid morning during a sunny weekday. If you have a lot of solor already in the street, the voltage may be very high when no one is home - and everyones panels are trying to make them money. They push the voltage up in a localised area, and can affect how well other systems in the area run. Stick a multi meter in a power point - if it is up around 255 volts at the times stated, I would do some more research.
    You could end up putting a large system in, and not seeing the benefits you may think you will get...
    Don't get me wrong - it can work very well, but in some areas, we are already seeing PV reach its saturation point...
    DiscoMick Guest
    Sounds a bit high. We only paid $1900 for 1.5kW, although the prices seem to keep changing. Suggest you get some more quotes.
    Ellendale Tasmania.
    We have the 3kw system, ours has 12 panels though(2 rows 2 arrays) unless you have the rebate of 60c don't bother, you will need 5kw as a minimum to see any real savings in your power bill.
    You'll need a good north facing roof area with no obstructions for the panels.
    Baz.
    Cheers Baz.
    2007 BMW R1200GS
    Mar 2012
    Quote Originally Posted by d@rk51d3 View Post
    Good point here. All they people I know have young to late teens kiddies,
