Please ignore, I just found the destructions! Seems I was tackling it from the wrong end!
http://www.media.ironman4x4.pl/files...otation_im.pdf
I've got an Ironman 9500lb winch. I want to spin the gearbox around 90deg so that the engage/disengage leaver is on the top allowing me to just reach through the hole in the top of the ARB Sahara bullbar.
I took the small bolts off the top cover, I originally thought they would be long all the way through the body and then I could just spin it, but not so. Do I keep pulling all the gears out now?
Winch:
ARB Sahara bullbar:
I was going to say start at the other end.![]()
Yep, beat me to it. I did mine without issue but did follow the instuctions. While it's out it would be a good time to give all the gears a good grease.
Cheers, David.
My Land Rover has made me a better Mechanic........
D2 TD5 Manual, CDL, Detroit Rear, Truetac Front, 2" OME lift, 32" MT Tyres, ARB Bull Bar, Winch, TJM Roof Rack, Driving Lights, Dual Batteries, ARB Side Steps, Rear Draws, Uhf.
