Results 1 to 4 of 4
Thread: Advice Needed D2a
    Dec 2012
    PRIMBEE, Wollongong NSW
    Advice Needed D2a
    Attached are some foto's of the cross member under the bellhousing of my V8.
    the problem i found while starting to fit a steering guard(APT)was that the front drive shaft hits the crossmember at full travel of the suspension,it has 2"lift and Terra Firma +50mm shocks.after removing the crossmember i found i would need at least 30mm spacers for it to clear at full travel.
    My question is this?,is there an after market Xmember or do i modify this one myself.
    i will be replacing the brake lines also B4 offroading as they look stretched also
    short of lifting the whole thing up with a crane to extend the suspension what else should i look for B4 doing any Mild offroading.
    Thanks in Advance
    Paul
    NSW SW Slopes
    Make-up spacers and replace the bolts with ones of suitable length.
    Jan 2008
    Grange, Adelaide
    Usual process is make your own spacer.
    I added about 16mm spacer using multiple sheets of 3mm al plate after my 2" lift. You'll need longer bolts. M8x1.25 x 30mm long is what I used.
    dimensions here
    Feb 2011
    Hobart, Tasmania, Australia
    I run Les Richmond Automotives angled spacer for my 3" lift kit. Check out their White Tiger range or products.
    Terrafirma do a +2" stainless steel braided brake line kit which is good. Although with a 2" lift, the front lines seems to still be fine, just the back ones that are a bit short. On a mates D2 we fitted my old front lines to his rear to solve this.
