I think the effect on performance occurs once the oil makes its way to the ECU. There it has effects such that the engine will not rev to its full range and will not go much past 2500 rpm.
There is not much worth doing to the loom given the oil makes its way inside the individual wires via capillary action.
The reason for removing the EGR valve is to remove the aerodynamic blockage to the inlet airflow therefore improving the breathing efficiency of the engine.
