Results 1 to 10 of 21
Thread: tips/warnings engine swap
    Aug 2008
    latrobe valley victoria
    Morning all,
    Over the next week/easter im swapping engines in my 56" with a later 2 L which is a lot fresher.
    any tips, warnings,words of advice not covered in the manual?
    ps putting new g box and engine mounts in as well,and have asistants and a hoist.
    regards mark
    {best to be aware before easter}
    all being well its then safty inspection and vic roads after the holidays
    Apr 2002
    Godwin Beach 4511
    32.38 MB
    sounds like a fun weekend!
    enjoy...
    2007 Discovery 3 SE7 TDV6 2.7
    2012 SZ Territory TX 2.7 TDCi
    Aug 2010
    Western Australia
    Core plugs!!!
    Aug 2008
    core plugs done, also valves, w pump and timing chain..
    It sounds good to go.
    Sep 2006
    Warragul
    spread bore
    Quote Originally Posted by mfc View Post
    Morning all,
    regards mark
    Hi
    I hope it all goes well..... the later 2 litre motors had a different starter motor setup - it works in reverse to the earlier engines , I think you need the correct bell housing to match things up
    Mike
    Aug 2008
    Quote Originally Posted by series1buff View Post
    Hi
    Mike
    yea i have to check that tomorow{i had a breif glance and they seem the same} ive got both the bellhousings and starters,but i dont know if the donor works, worst case its swap belhousings i guess . the workshop and parts manual list the same for both engines going by serial no....
    Hi
    Mike
    The starter motor shaft spins the same direction, but the pinion cog engages the ring gear from the gearbox side from 1955 onwards.
    The bell housing needs to be the type with a longer protrusion of the side of the housing to accommodate the longer bendix spring arrangement .
    Aug 2008
    hmmm.... meter plug for oil line banjo bolt.
    there was none . Would this in combination with buggered inlet valve seals lead to oil being sucked into the cylinders and excess oil sitting under the rocker cover?
    Any idea who sells them?
    Sep 2006
    Warragul
    plug
    You might have to make one up..... Do you have any small drills ?
    I will have a look and see if I can find one ...... at least to measure the hole in it
    Mike
    PS just went outside and pulled the banjo off a spare head..would you believe it, the metering plug is missing #$%%&&
    At a guess the hole is about .050 " diameter
