Results 1 to 10 of 11
Thread: Td5 Oil Pump Bolt
    Feb 2013
    Canning Vale WA
    Td5 Oil Pump Bolt
    Hi guys, so I'm loving my Disco Td5 but I'm getting worries about this Oil Pump Bolt stuff. Do I desperately need to have it changed, or should it be fine by now? Cars got 265,000 kms on the clock if you were wondering.
    Ben.
    Oct 2011
    Fremantle WA
    Each to their own, and others may disagree, but when I bought my wee beastie at 130K, I had a pretty thorough going through done just for my piece of mind and to create a datum point. That included oil pump bolt, hoses, drive shafts/coupling, all fluids changed, fitting Provent, purchase Nanocom/Rave/Microcat, EGR, low coolant alarm, MAF - and then I started on the mods for towing/touring.
    Australia
    It's an hr of your time for piece of mind done with an oil change or $5k plus if it hasn't been done.
    If the previous owner can't confirm it being done just do it.
    Plenty of posts on the topic.
    IMO (said with politeness) no sympathy for someone aware of a potential failure who is reluctant to check.
    Dec 2010
    Brisbane Bayside
    Do it!!!!""
    We own 2 TD5's...one shed it's bolt and nearly destroyed the engine..the other was checked ---NO LOCTITE either ..keep an eye on the spot for the oil light until you get it done..
    Free Again Thanks Dan
    Quote Originally Posted by strangy View Post
    x2 It will be cheaper now but if it goes big $$$$$$$$$ with out checking it
    Jan 2012
    If your thinking about it, do it.
    I did mine recently and found it was already nice and tight with loctite applied. At least I'm not thinking about it anymore...
    Jan 2009
    Australia, Brisbane
    I was aware Didn't do it until it happened to mine had 270000km on it, had no damage from the bolt falling out, while I was under there I changed the bottom end barings noticed the motor ran a lot quieter - relatively easy to do.
    Sent from my iPhone using Forum Runner
    Dec 2010
    Brisbane Bayside
    The bolt won't hurt the engine,,its the lack of drive to the oil pump that destroys it..unless you see the oil pressure light come on and shut it down. It hurts to drive with your fingers crossed.
    Feb 2013
    Adelaide
    Hi Guys, Just purchased a 2004 TD5 S.
    It has an engine number of 16P23305A.... Should I be checking the oil pump bolt or did they have it sorted by this this time? The VIN is dated 09/04.
    Kingston, Tassie, OZ.
    CHECK IT!!!!!!!!!
    NONE are immune.
    JC
