29th March 2013, 08:22 AM
Audible low oil pressure alarm
I've fitted the TM2 combo so have low coolant and head temperature covered. Also checked oil pump bolt.
But I still read of lock tighted bolts coming loose.
So has anyone got a simple suggestion for installing a buzzer that will come on with the oil light?
Then if the bolt fell out and light came on and I was watching the road and didn't notice the buzzer would do the trick. I realise it would also buzz at start up before the engine starts, but this also confirms it working.
Any ideas welcomed
Willis
29th March 2013, 09:31 AM
The TM2 already has this feature. Simply tap into the oil pressure switch. Instructions should be with the unit. Yes, the buzzer is a bit annoying when you just need ignition on.
Robbo
29th March 2013, 03:54 PM
The orange wire goes to the oil switch which then will give you a 10 second delay while you start it, as robbo said it will sound if you need ign on only
Ken
