Results 1 to 8 of 8
Thread: Need A Faultmate in ADELAIDE PLEASE!!!
    taffy241255 Guest
    Hi all,
    Anyone in Adelaide who can help? Have a SRS and message centre AIRBAG fault , bulbs ok , did it when I removed dash for a new A/C matrix
    96 HSE so no side airbags etc , any help would be great and SAVE money.PS did reconnect battery before finishing replacement of airbag.
    Feb 2010
    Drive to Melbourne and you can use mine
    taffy241255 Guest
    Quote Originally Posted by BusinessConnected View Post
    Thanks , but do not have the time or money at the moment!
    May 2008
    Ask in the Diagnostics forum for someone who has a Nanocom Evo with P38 unlock codes. The codes are different for GEMS (pre-99) and Motronic (99+) models, so check this too.
    Nanocoms are multi-vehicle by default, whereas FaultMates are single-vehicle by default.
    Best wishes, Paul.
    Adelaide - Torrens Park
    I have a multi vehicle scan tool which might work with a P38. I have never plugged it into one as none of my customers drive P38s.
    taffy241255 Guest
    Quote Originally Posted by PaulP38a View Post
    Best wishes, Paul.
    Thanks Paul I will check it out!
    Apr 2007
    South Australia
    I have a tool but unsure if it will unlock SRS, where bouts in adelaide are you?
    2007/2002/2000/1994/1993/1988/1987/1985/1984/1981/1979/1973 Range Rover 1986 Wadham Stringer
    and a Nissan Cube............
    South Australia.
    Apr 2007
    South Australia
    Can anyone else help out in Adelaide?
    I see you posted in the dagnostics forum so hope someone helps out!
    South Australia.
