Results 1 to 10 of 13
Thread: anyone put a land cruiser ute tray on a 110 defender
    Apr 2011
    alice springs
    i might be able to get a 75 series land cruiser steel tray for cheep and was thinking about chucking it on my defender but im just wondering how well it will match up. im not expecting it to bolt strait up into the existing mounts but i am hoping that i wont need to chop it up lengthen or shorten it or have to make any major changes to it. so long story short has anyone put a cruiser tray on there 110 defender or looked into doing it?
    Apr 2011
    Whyalla S.A.
    Although not to a 110, I've shortened by 2 floor panels a Githsam aluminium tray to siut the length required to fit my Puma 130.
    The tray has C channel chassis rails running front to back, I simply fitted 150mm C sections across to align the tops of the chassis and bolted where required.
    It only took my wife and me about 2 hours to sit it on the chassis, size up and bolt it down to drive away.
    Looks much better than the steel module I am making for it.
    Apr 2011
    alice springs
    thanks for that ill have to have a look at the tray and see if it has the some rail thing. also did the head board/roll bar line up with the top of the cab?
    Apr 2011
    Whyalla S.A.
    it sits about 20mm higher, purfect for what I wanted for carrying my kayak.
    May 2010
    Delegate NSW
    Hi lndrvrboy, is the photo you have put up of your Defender now? in which case if you do end up swapping to a Land cruiser tray, would you be willing to sell your tub?
    Adelaide - Torrens Park
    If you want to convert a tub type Defender into a trayback you will need a replacement back wall.
    Apr 2011
    alice springs
    I have the cab panel that is needed that came with the car when I bought it. yeah it is my ute in the photo and if I do put a tray on it then I may sell the tub but I am in Alice springs so it my be expensive to transport. Thanks for the help guys ill see wether I can get the tray or not and ill let you guys know how I go.
    austastar's Avatar
    Jul 2009
    Hobart
    Hi,
    Make sure the wheel clearance to the tray is greater than the bump stop clearance on the rear axle. Otherwise you will graunch the tyres crossing ruts in tracks.
    Apr 2011
    alice springs
    Yeah will do austastar I will probably lift it up a bit so I can keep the length for dirt bikes and still have a decent departure angle
    Apr 2011
    alice springs
    thought of something else that could be an issue... how will the fuel filler thing mount? anyone have a close up of where there's is?
