Thanks. Looks OK. I need something too.
PS. Whats with the bonnet?
just thought id pop up a photo of an Exmoor trim pre production 80 inch hood{flat hoodsticks} fitted to an 86 inch
Please forgive the dodgy hoodstick, its first try and im going to bend up another with more accurate 6 inch radius bends, its also bent to the rear a little to much.
unshure of what you mean re bonnet?... apart from painted spare holder i thought it was normal lol...dont tell me its off an 88 inch or somthing{cant bee cause theres under an inch overhang at rad pannel????
only downside of the hood so far is that it has 1o loops not 9 like te 86 inchs,
i thought id get the tabs relocated fter its shrunk . But 2 short peices of high tensile wire hold it fast and are neet so i may leve it like that
bear in mind that the hoodstick was bent around a tree and the corners arnt 6 iknch radius , hence the way the canvas looks a bit creased and the fume curtain isnt held down with the straps,just the silver clips
regards
mark
2002 defender 110 , 1955 86 inch
No problem. Just the photo makes the overhang look longer than an inch.
Sorry to read about your troubles. Maybe a compression test will show something.
 Master
						Master
						the overhang at front is about a cm from radiator panel{any shorter and youd struggle to open it with tire on bonnet} so I guess its an 86 bonnet
How much did they charge for freight?
freight was 70 pounds I think ill confirm 2morow
{john craddock}
quoted 50 pounds ..actual 60 pound{10 kg} fast from uk to Melbourne {3 days} slow from Melbourne to Gippsland lol{10 days plus}
 Fossicker
						Fossicker
						why did you get a 80" 3 seater and not a canvas made for an 86" land rover??
