Results 1 to 3 of 3
Thread: Scanner recommendation
    Somewhat North of Cape York...
    Hi all,
    I'm in the market for a scanner in order to get my negatives on the hard disc. I don't need a professional device, but I don't want to step back on quality. I was recommended a PlusTek (there are two different choices, called 8100 and 8200i SE, respectively), but these are not that easily available locally. I may consider ordering one online.
    Any other suggestions?
    Ta, mates!
    Johannes
    There are people who spend all weekend cleaning the car.
    And there are people who drive Discovery.
    May 2002
    Heathcote (in "The Shire")
    I've had a plustek 7200 for a number of years, and it's been a good unit (although I suspect now superseded)
    Scan from 1985 slide (IIRC)
    Scan of 1977 negative.
    The biggest influence will be the condition of the slide/negative with regard to scratches or mould etc.
    You can however get some great results with a little patience and work.
    Martyn
    Jan 2013
    Tasmania
    What's the budget?
    Myself and one of my neighbours are heavily into film photography and when he got a scanner there was much researching before an Epson V700 was purchased.
    Retailed for around $700 but there's probably a newer model now, you might even get a secondhand one cheap.
    Flatbed but bloody good and has the holders for negatives and slides and medium format and large format sheet film and comes bundled with Photoshop Elements....
    I was going to buy one myself but a local pro lab shut down and I scored their huge Kodak Professional PCD 4050 which is ten years old but was a $15k machine new....
