Results 1 to 10 of 16
Thread: HELP - Very quick question?!
    Aug 2012
    North Loburn, New Zealand
    Does my 08 Puma have a low range light that should come on the dash when selected??
    Aug 2012
    Adelaide
    I dont' have one (defender) but my understanding was that there was only a 4x4/diff locked light. not a low range light.
    Feb 2005
    Quote Originally Posted by Tikka7mm08 View Post
    i assume it would have centre diff light like previous 110's as a reminder......shouldn't need a light for low range....
    Aug 2012
    Yep I have that one, I wondered if it was the mountain one that came on?
    Apr 2010
    Connolly, WA
    Hi Tikka,
    An 08 Puma should only have the orange "Centre Diff Locked" light illuminate when the diff is locked in both high and low range.
    There is no separate light for high and low range (pretty difficult to not notice those).
    We've had a long discussion about the "mountain" one, but as far as we can tell the Australian version of the Puma has no reason or ability to have the mountain light illuminated.
    The only other light you'll see off road is the orange "TC" inside a break disc symbol which will indicate when you're traction control is active (can't select that on or off) which happens automatically.
    Hope that helps!
    Lou
    Aug 2012
    Ahh - its says in the manual it comes on but actually that is only on Disco's... for some reason it doesn't do it on Defenders.
    Aug 2012
    Thanks Lou - I don't have TC... oh well, I do like the little lamps that aren't alerts for major faults
    Apr 2010
    Connolly, WA
    Tikka,
    You said before its a UK import to NZ...?
    I'm 99.999% sure it does have TC, you just need to find something challenging enough for that 90 to make it activate...!
    There is no switch, it functions automatically with the Defender's ABS.
    Lou
    Aug 2012
    Yes that's right - off on Mon to get completely wax oiled or such.
    No doesn't have TC and no ABS. It has the square rear wheel 'arches' and that let's me fit 4 side seats. Wanted a 'new' truck but 5 doesn't go into 4 so this has worked out well.
    Apr 2010
    Connolly, WA
    Well that's stumped me completely... I wasn't aware that Puma's had an option not to have ABS.
    Could you post what waxoil type deal they're doing to the car when you find out please? If it's UK style waxoil it would not be of any use this side of the pond (temperature wise), but looking at my surface rust starting I would very much like to find an "apply and forget" product.
    Lou
