Results 1 to 10 of 12
Thread: rego question??? 1955 requirements
    Aug 2008
    latrobe valley victoria
    im fairly shure I know the awnser is one but....
    was it required to have a passenger side windscreen wiper?
    most ive seen only have one now
    ps 1955 86"
    regards mark
    2002 defender 110 , 1955 86 inch
    Bunbury, WA
    I can't offer anything constructive other than to say, I hope not!
    Mine has definately never had a wiper installed on the passenger side, there is a set of mounting holes there but the cover plate has never been removed.
    I guess I'll know when mine goes over the pits in the next couple of months...
    Simple answer is no - not fitted as original so not required now.
    JDNSW's Avatar
    As above - not required, but you may have to argue the point. Note that turn indicators are not required either, but fitting them would be a really good idea!
    Bunbury, WA
    And the same for seat belts!
    Narre Warren South
    Quote Originally Posted by cjc_td5 View Post
    Problem is, do you have to 'engineer' the fitting of seatbelts if it never had them fitted ?
    Colin
    '65 Series IIa Dormobile
    '70 SIIa GS
    '76 SIII 88" (Isuzu C240)
    '81 SIII FFR
    '95 Defender Tanami
    Motorcycles :-
    Bunbury, WA
    Quote Originally Posted by gromit View Post
    Colin
    Taken from the WA Dept Transport website:
    Modify a vehicle
    ...Modifications that don't require approval
    Many minor vehicle modifications can be carried out without specific approval, as long as they comply with the applicable legislation. Modifications that don’t require approval include:
    Additional lighting
    Air conditioners
    Air shock absorbers
    Alarm systems
    Badge bars
    Body markings and speed striping
    Gearbox (pre 1976)
    Mesh stone shields for wind screens and lamps
    Mud spats and pebble guards
    Optional manufacturer seating
    Radio and stereo systems
    Rear-view mirrors
    Roof racks
    Seat belts for pre 1969 cars (no full harness types)
    Single tone air horns
    Stabiliser bars
    Sunvisors
    Torque rods and traction bars (not semi-tramp types)
    Tyre size and aspect ratio
    Venetian blinds and other internal screening systems are allowed, subject to a clear view to the rear...
    Seems OK to me to fit seatbelts in WA without engineer or other approval...
    (Sorry for the thread highjack mfc).
    Narre Warren South
    Modify a vehicle
    Additional lighting
    Air conditioners
    Air shock absorbers
    Alarm systems
    Badge bars
    Gearbox (pre 1976)
    Rear-view mirrors
    Roof racks
    Stabiliser bars
    Sunvisors
    Thanks for that.
    I'd still be concerned about how/where you mount seatbelts in a vehicle not designed for them (although with a Series I you just look at how they mount them in a Series III and copy because little has changed).
    In a Series II that I own the upper point for a static lap/sash is just bolted through the truck cab side with no reinforcing plate. The aluminium is quite thin so I wonder how strong it would be.
    From VicRoads website "If you make modifications to your vehicle, you must notify VicRoads and they must comply with the Australian design rules" but most mods they list are seating numbers, engine number colour etc.
    I'll have to investigate further.
    Colin
    '70 SIIa GS
    '81 SIII FFR
    '95 Defender Tanami
    Motorcycles :-
    Aug 2008
    ive been told that there is adr approved lap belts available from qld but I have to check{forgot the companys name and not certain if landy ones are available}
    ill post up here when I find out
    Narre Warren South
    Quote Originally Posted by mfc View Post
    The belts are available locally even places like Autobarn should be able to get them (APV/Klippan part number K1637 should be the one). The issue is the fitting of them to a vehicle that never had them originally.
    Colin
    '70 SIIa GS
    '81 SIII FFR
    '95 Defender Tanami
    Motorcycles :-
