Results 1 to 4 of 4
Thread: 54 SWB rear axle
    Raven Motorsport Guest
    54 SWB rear axle
    Hi,
    I recently purchased a 54 SWB and I need a RHR semi floating axle as mine is badly twisted at the spline. Does anybody make new ones or where can I get a good used one.
    Is it possible to convert it to a full floating one or is the main banjo unit different or will a Series 2 full floating diff bolt in?
    Alastair
    australia
    Quote Originally Posted by Raven Motorsport View Post
    Hi,
    Alastair
    email regards axle jim
    JDNSW's Avatar
    JDNSW is online now RoverLord Silver Subscriber
    Hi,
    Alastair
    It is simple to convert to full floating. The full floating stub axle just bolts on. Late lwb Series 1 had this. The only catch is that the half axles are shorter than Series 2, and scarce as hen's teeth. However, the Series 2 axles fit with a spacer made by turning the centre out of a Series 2/3 drive flange, and this is a common conversion.
    You will need to locate longer bolts - which are BSF.
    Queensland
    I have a couple here but a long way from you. If its not a show piece convert it to full floating.
    Keith
