First thing I'd look to is who installed the rear diff lock, they probably botched it. For starters your better off with a Truetrac than a difflock, esp with TC / ABS.
If they didn't install heavy duty axles at the same time and remove the inner axle, stub seals & convert to oil filled hubs my guess if your rear axle splines / flanges are stuffed.
chock the wheels good, front and back.
release handbrake
put transfercase and main gearbox in neutral
get under car and try to turn each propshaft ,
if you can turn either propshaft anymore than about 15-20 degrees you have a
problem
if you have a rear difflock you should have less backlash than normal,
if you have excessive backlash remove your plastic caps off the drive flanges (in the center of the hubs) get someone to watch the axles move in the spline as you turn the props back and forth, there should be bugger all, any movement and your drive flanges are stuffed , probably from running dry.
if your backlash in the diffs axles seems fine, then put the transfer case into gear and grab one prop in each hand and turn them back and forth against each other. take note of the amount of movement, then engage center diff lock and recheck propshaft slop , if its significantly less with difflock engaged you might need transfer case work.
if all that seems ok you need to look toward suspension - e.g. rear balljoint ontop of the diff or trailing arm bushes are probably stuffed.
					 ), and even the spud shaft from the gearbox to transfer case input flogging out the splines due to incorrect hardening, plus axle drive flanges front and rear.
