Results 1 to 10 of 15
Thread: D3 Fuse Box where to buy?
    Jan 2012
    hello Together,
    Just picked my car up from Davis Performance and the wallet is 2.6k lighter but therfore the car does not sound like a metal factory anymore.
    Had the lower control arms, sway bars, breaks and rotors replaced And Bruce found the issue I have intermittently with my air conditioning where it stops working. It seems like I need a new fuse box does anyone know whether I can order that from the UK?
    I believe the fuse box needs to be coded to the car but a quick search on Google did not yield any results and companies like Brit parts do not seem to stock them.
    Thanks a lot
    Steve
    Dec 2011
    Bundeena
    Steve, is it the one in the engine bay or the passenger foot well?
    Sean
    If it is the one inside the vehicle behind the glove box (Called the CJB or Central Junction Box) then it is a VIN order only & the CCF files will need to be written to it & then sent from the UK. It is basically the brains behind the vehicle & a major component.
    Sent from my iPad using Forum Runner
    Jan 2012
    Sorry guys should have specified the one in the engine bay next battery
    Jan 2012
    DP charges $790 for the box just wondering whether its worth while ordering from UK and from where?
    Dec 2011
    Bundeena
    Steve, which part did he say you needed from the attached pic?
    Sean
    Jan 2012
    hello Sean,
    thanks for the picture Bruce, suggestion was to replace the whole box he said he could start pulling it apart and look for loose connections and see whether he can find it but there would be no guarantees and I may still have to purchase the box.
    Any idea what the box including the matching to the car cost in the UK and where I can order it?
    Thanks again guys for the help.
    Steve
    Dec 2011
    Bundeena
    hey Steve, from what I can see LR only supply the fusebox with the wiring loom already wired together - not sure if this is right though. There are different part numbers depending on the configuration of your car too.
    The part I found which may(not) match your car is LR014709 with a description of:
    WIRE, INCLUDES FUSE BOX, LION DIESEL 2.7 V6 (140KW), 6 SPEED AUTO ZF 6HP26 STEPTRONIC, RHD, WITH FOUR CORNER AIR SUSPENSION, WITH HALOGEN HEADLAMP, WITH BI - XENON HEADLAMPS
    Not cheap either:
    Famous Four - Land Rover Part LR014709 - WIRING
    I would say, if you wanted to be sure of the part, have him supply you the part number so you can be sure of what to look for.
    Sean
    Jan 2012
    Thanks a lot I think it is then cheaper and safer to purchase from Bruce for $790. If that UK box would not work it would be a hassle to get it return. I really appreciate your help though
    Dec 2011
    Bundeena
    Yep I reckon you're on the right track there mate.
    Sean
