Results 1 to 10 of 14
Thread: Winch install
    Jul 2007
    Brisbane North
    Winch install
    While installing my Tigerz11 12000 it came to my attention that the brackets to mount the control box on top of the winch weren't included. So I went hunting for a new position to mount the whole control box, but in a Puma engine bay there is no way that will happen.
    So the I went hunting for a position for the solenoid. The best place I found was under the drivers seat. This is how it all went.
    Inside seat box
    Isolator and in/out toggle switch. The switch is rated at 3000amp.
    Passenger side battery box
    To protect the cable/plastic protective case stuff from the heat from the exhaust its been wrapped in Kevlar
    Im hoping the solenoid prefers the serenity in a nice little box out of the weather!
    in the wild New England, NSW
    Thanks for posting this - it looks like you've done a good job.
    Often the control box is mounted exterally (sometimes on the winch).
    When I see this for a winch which hardly ever gets used, I do wonder if the owner realises that the contacts may get so corroded/dusted that the winch just won't work when required.
    Near Seven Hills, Sydney
    3000 amps? That's extraordinarily big, mains sub-station stuff, do you mean 300 amp?
    Sydney, NSW
    Quote Originally Posted by isuzutoo-eh View Post
    It may well have a 3000A surge loading for a few ms, but I doubt very much it could sustain that figure any real purpose. Having said that it only needs to e able to sustain possibly 700A for winching, even then that would only be under maximum load. 400A would be much more normal current.
    Sent using Forum Runner
    Regards,
    Jon
    Mar 2013
    East Gippsland
    Aaron I am locking at fitting a winch to my puma..........from the photos it appears you have only one battery is this correct, I thoght an axtra battery was required to cope with winch draw. If i can get away with a single battery it would keep costs down
    Cheers Paul
    Sydney, NSW
    Quote Originally Posted by bemm52 View Post
    Cheers Paul
    You definitely do NOT need a second battery to run a winch, however, bear in mind that you will need to keep your engine running whilst winching if you only have one.
    A second battery simply ensures you can always start the car after you have recovered yourself (or others), it is nothing to do with current draw from the winch / winch operability.
    If pennies are tight and you need a winch, just use the one battery. You can always add a second battery and associated other requirements at a later stage.
    hth
    J
    Regards,
    Jon
    Aaron did you leave a plug for the winch remote on the outside too?
    we have the winch controls on our puma on a contura switch up near the steering wheel..however if you dont have the ability to plug the remote in as well your going to have issues if your ever out on your own and have to use the winch because you cant sit in the car and wind the winch rope back on, on your own.
    This is a mistake we made with our puma although I always go out with Ian so not an issue for us but one I'm not going to make with the disco..I will make sure I have a plug under the bonnet as well as a control switch in the cab
    Jul 2007
    Brisbane North
    Its 3000 initial and I think 750amp continues. I can check the invoice if needed.
    Jul 2007
    Brisbane North
    Yeah that was an oversite to be honest. It will be annoying, but still do able. I will probably get a second plug installed for the situation (Which is code for "will never get around to it!")
    That is one very long path for the current .
