Hi All,
Just a couple of shots to show people making a fridge slide and false floor using the 4 anchor points is very easy to fabricate if you can cut and weld.
This setup can be installed/remove in 10-15 minutes.
The slides are rated to 125kg and extend 900mm, making access to the fridge from the rear easy. To-date the basic set-up now has cost me around $195.
Gerald
VK3GJM
Hi Kevin,
Thanks. You have your priorities right. Yes, HF/VHF/UHF will be mounted somewhere up high.
All this for the up coming Cape York Trip.
Gerald
VK3GJM
Hi Kevin,
Don't bother yet. I am leaving for Atherton on the 26th August. Got a while to go yet. Happy to make an announcement the day I leave. Yes it would be good to have a chat.
I run a Codan 9350, I can tune up anywhere.
Gerald
VK3GJM
