Results 1 to 10 of 17
Thread: Second hand gearbox
    Bellie_666 Guest
    Second hand gearbox
    Hey guys and girls...
    I took the disco in to be serviced due to the gears sticking till warmed up, and the mechanic has advised it's time for a new gearbox.
    The cheapest he could find was a reconditioned one for $3,300 which is a bit out of my price range.
    So I'm looking for a second hand one. Does anyone have one lying around that they would like to get rid of?
    Also is the gearbox the same for the 300tdi as the v8s and the range rovers?
    Cam
    Narre Warren South
    Quote Originally Posted by Bellie_666 View Post
    Cam
    Sticking till warmed up sounds like an oil problem.
    What oil is being used ? It is perfectly OK once warmed up ?
    I'm still running ATF in my Defender gearbox and it has no problems but I know a lot of people recommend Syntrans or similar.
    Colin
    '65 Series IIa Dormobile
    '70 SIIa GS
    '76 SIII 88" (Isuzu C240)
    '81 SIII FFR
    '95 Defender Tanami
    Motorcycles :-
    in the wild New England, NSW
    Cam
    I wonder on what basis the mechanic advises a gearbox change .....
    as gromit posts above - a useful step for a manual may be to try an oil change to Castrol Syntrans
    otherwise a number of people have used Ashcroft Transmissions whose price for a reconditioned one landed in Oz will be much less than you've been quoted
    99.87 MB
    Auto or manual?
    Slunnie
    Auto or manual?
    good point .. for some reason I assumed manual - may not be - if an auto don't use syntrans, but get it serviced anyway
    Bellie_666 Guest
    It's an 94 auto 300tdi.
    He said that the gearbox appears to have had water in it. Also there is clutch material in the oil...
    Moruya Heads/Sth. Coast, NSW
    Get an oil/filter change and see how it goes, sounds like the governor is sticking, I had the same problems and a filter oil change fixed it, Regards Frank.
    99.87 MB
    I'd say that if there is clutch material in the oil then that box is already well on its way down that slippery spiral.ive found that the fragments caused heap of problems through the box and the governor probs are indicative of this.
    Slunnie
    Jan 2013
    Penrith
    Im thinking if there is clutch material in the oil of an auto, theres a massive problem....
    St Helena,Melbourne
    4.28 MB
    Quote Originally Posted by Kevin B View Post
    Auto's do have clutches you know.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
