Results 1 to 10 of 11
Thread: optima battery new voltage?
    cairns
    I bought a new red top Optima for my td5 defender on Wed. and went to install it today.
    Out of interestput my volt meter on it just before i was to put it in and suprise, suprise 11.7 volts.
    I so rang the place where I purchased it and was told it was probably my volt meter. I politely let them know it WASN"T my volt meter.
    So the salesman went and checked the other stock.
    The ones he tested were between 12.2 and 12.4 volts.
    So............. I took my battery back and was given another one (straight off the charger) It tested 12.8 but was 12.62 by the time I got home.
    Questions; what voltage should Iexpect with a new Optima?
    How old can a 'new' battery be? (bit of a how long is a piece of string Q but you know what I mean).
    So.........do I have a problem or is this normal, I usually buy Century so am a bit lost with the Optima agm thing for a cranking battery.
    Thanks,
    Paul.
    Paul.
    77 series3 (sold)
    95 300Tdi Ute (sold)
    2003 XTREME Td5
    I thought I was wrong once, but I was mistaken.
    Alex Heads
    Sounds like an old battery, not that uncommon.
    If it's sat on the shelf for too long, and not rotated out, it can be a couple of years old by the time you get it. If it hasn't been charged or cycled, it'll be no good.
    Love Optima for deep cycle stuff, but I'd go a Century for cranking.
    Sep 2012
    Adelaide Hills
    Quote Originally Posted by harro View Post
    err, that sounds like normal
    open circuit voltages, % and density
    12.60 V 100% 1.265 g/cm3
    12.35 V 75% 1.225 g/cm3
    12.10 V 50% 1.190 g/cm3
    11.95 V 25% 1.155 g/cm3
    11.70 V 0% 1.120 g/cm3
    cairns
    Quote Originally Posted by Eevo View Post
    Thanks for that info.
    I always thought 12.8 was fully charged for a flooded lead acid and even higher for an AGM.
    So maybe no problem at all.
    Cheers.
    Paul.
    Paul.
    77 series3 (sold)
    2003 XTREME Td5
    Sep 2012
    Adelaide Hills
    Cheers.
    Paul.
    if its just come off a charger it might be 12.8 or higher due to surface charge.
    Sep 2012
    Adelaide Hills
    hmm, i could be wrong
    http://optimabatteries.com.au/wp-con...-YellowTop.pdf
    Open Circuit Voltage (Fully charged): 13.1 volts
    and the red top are 12.8volts
    and wiki says 12.6volts hmm who to believe
    99.87 MB
    Quote Originally Posted by FenianEel View Post
    I think the big advantage of the Optima is realised 5, 6, 7 years down the track when they're still working like new. I also think that there are awesome Optimas and crap ones, depending on which one you happen to pick up off the shelf.
    Slunnie
    Queensland
    Hi Eevo and Open Circuit voltages vary from one battery type and make to another, but as you posted, for a new battery, that is way too low and should be replaced under warranty.
    Paul, I would be demanding a replacement or your money back.
    No new battery off the shelf should have a voltage of less than 12.4v.
    BTW, how much did you pay for it?
    Sep 2012
    Adelaide Hills
    do stores charge batteries in stores?
    if a battery has been sitting for 2 months i can be a 12.4v
    it would require a charge and nothing more. nothing actually wrong with it
    Queensland
    If they look after their SLOW turnover stoke, they will charge them periodically but in the case of an Optima, because they hold their charge for a very long time, to be at 11.7v, it would either be faulty or have been on the shelf for a couple of years.
