Originally Posted by
Nomad9
HI Dayswaste,
Understand the comment about the "If not serviced run away" comment, and the reasons why. I've just bought a 2001 110 TD5 that had been regularly serviced by a reputable Land Rover dealer, I'm doing a bit of a trip later on in the year so I decided to do the EGR removal, a precautionary head gasket change, silicon hoses and a few other small jobs.
Since removing the head I've found two exhaust manifold studs sheared off, one had fallen out and the other was hanging on for grim death, the previous owner had complained about an oil leak "around the back of the engine somewhere", when I removed the head it looks like some siliconed string had been caulked in between the head, the gearbox and the block to stop the leak, obviously it had worked but surely you would have thought that this would have been fixed properly unless the oi leak was noted during the warranty period, a little bit synical I know.
If you find a well cared for vehicle by a fastidious owner this would also be worth a look, I wouldn't discount entirely vehicles that have been serviced by the owner, some tend to do a better job. Personally I pride myself on the extremes I go to to look after my vehicle. I know a few other LR owners who are the same, sort of goes with the marque.
Good luck finding what you are after.
