Results 1 to 2 of 2
Thread: 2008 Puma, Engine warning lamp- MAP fault
    Jun 2008
    Drouin East, Vic
    I've had the engine warning lamp illuminate several times over the last few weeks, the first time it stayed on for a day or so then went out of it's own accord, last time it stayed on for several days, until reset. The recorded fault indicates MAP out of whack. After thoroughly cleaning the MAP sensor, all seemed well for a couple of days, even had more power (although the vehicle seemed to be running fine throughout), but now the light has come on yet again. What else could be causing this fault code? Could it be the EGR? If so, what needs to be done with it?
    Central Coast NSW
    If it is the EGR, then a BAS remap with EGR electronically closed EGR will sort it out
