Results 1 to 10 of 14
Thread: Possible cure for Defender roof leak?
    Feb 2010
    sydney
    If anyone is interested, I've found a new 3M product called 'Extreme Sealing Tape'. If it does what it claims it would be a perfect solution for stopping water ingress through the seemingly impossible to stop crack that occurs between the two roof panels on a Defender.
    It has excellant resitance to UV, extreme temperatures, moisture, and high water pressure. It's flexible, designed to stick to exterior metals for many years and comes in grey, white and black.
    It's not cheap and requires a 3M surface primer, but considering the amount of time and effort I've put into trying to seal that roof crack I think it is well worth it if it works. Probably a bunch of other places it could also be useful on a defender.
    I am waiting for 3M to get me a 50mm wide roll (narrowest available in Australia) cut into two 25mm rolls for IMO a neater solution. When I get it I'll give it a try and will post my results as I find them.
    Here's some technical info...
    http://multimedia.3m.com/mws/mediawe...6EVs6E666666--
    Feb 2010
    Deloraine, TAS
    What have you tried prior to this?
    I was thinking of giving this a go Capt. Tolley's Creeping Crack Cure.
    Simon
    95 Defender HCPU 130
    Feb 2010
    sydney
    Quote Originally Posted by Mr Ploppy View Post
    Sorry Mr Ploppy for not responding earlier. I subscribe to the threads that I start but for some reason I dont get the email notification when someone responds.
    In answer to your question, I've had a few body shops look at it and work on it which basically equates to injecting quality gap filler into the seam; unfortunately all their efforts fail as soon as I twist the body off road. Your product may work but I wonder how it will handle the similar shearing movement.
    I've applied the 3m tape and it certainly has stopped the water ingress, but the true test will be how succesfull it will be after I've twisted the body a bit which won't happen for a few weeks yet. Fingers crossed.
    Jun 2011
    Berowra Heights NSW
    Nah , take away the leaks you take away the appeal.
    What other veichle comes with leaks from new, and the dealer admits it?
    Oct 2008
    I am fairly sure that Aldi just sold something very similar to this tape - All Weather adhesive tape. Cost about $4. But looks very similar.
    Aug 2013
    newcastle
    Have you thought of getting the roof vinyl wrapped? Bonus is that
    It will look like a brand new roof and i can't see why it wouldnt stop
    Water leaking as its completely sealed.
    Qld.
    what's wrong with my Defy? It doesn't leak at all until I drive it through a river.
    2007 Defender 110
    1993 BMW R100LT
    Oct 2008
    The problem is that the roof is made of two separate halves, front and rear. When you flex the vehicle and the roof twists, the two halves slide over each other a mm or so at the seam. After a few years the mastic sealant that glues the seam together dries up and you end up with a seam that leaks. So now when it rains you get water dripping down onto the inside roof.
    One thing I've been meaning to try and I might have a go now, The mastic they use is soluble in turps, perhaps a mix of turps and oil might rejuvenate or soften the mastic again and allow it to seal. I distinctly remember the hours of work it took in softening the mastic on a classic range rover roof before I could pop it off... Maybe WD40 might do the trick.
    Quote Originally Posted by alittlebitconcerned View Post
    I would like to see some pics of how and where you applied the tape
    Wayne
    ​VK2VRC
    LowRange 116.76:1
    Feb 2011
    Richmond, NSW
    ...as would I.
    The dripping onto my arm I can handle, but the puddle in the footwell concerns me.
