Results 1 to 10 of 20
Thread: Another water pump failure
    Late last week, as I was rounding a corner I heard a strange rattley noise that lasted a few seconds and then stopped. Shortly after I heard a screeching/whistling sound that was quiet and lasted for a very short time.
    I couldn't work out what it was.
    After about 1km, the whistling started again as I rounded a corner so I pulled up to check. The I saw the steam from under the bonnet. Initially thinking it was smoke, I was going to bail and let it go but I opened the bonnet to see water everywhere.
    I assumed a blown hose but I couldn't find anything so I popped off the top fan shroud coverplate and then saw that the fan was cocked over at an angle.
    Another water pump where the bearings had collapsed. This is the second pump where this has happened. This pump was new and fitted when I had the engine rebuilt 35,000km ago in Oct 2007.
    When I got the serpentine belt off, I found the pulley was locked solid. I'd been hearing the belt slipping.
    So, having NRMA Premuim Care, I called for a flatbed to get the Rangie home.
    However, as many will know, I have a lot of luck with getting stuff.
    After an hour when the towie still hadn't arrived, I called the NRMA to chase it up. I was told the truck's winch had failed so another truck had to be called. It finally arrived after 2 hours waiting in suburban Penrith.
    Note how the impeller is off-centre and scraping the housing. The rear bearing has collapsed.
    Feb 2010
    Townsville, QLD
    It always happens when your roadside assist are in tip top shape too!
    Out of curiosity what make was your water pump?
    Coogee, South of Fremantle, WA
    Was it loosing coolant from the pump when it went, When mine went it was leaking so the low coolant alarm saved any dramatic boil over. At least they are easy enough to change and not to pricey
    Feb 2010
    Townsville, QLD
    I believe he said 35,000km and oct '07 above
    Quote Originally Posted by Keithy P38 View Post
    Yep I re-read it and edited my post, obviously whilst you were replying
    Quote Originally Posted by wayneg View Post
    No loss of coolant. No dribbles from the hole under the bearing housing.
    Would you believe my low coolant sensor failed a couple of weeks back and I'm awaiting a replacement.
    Apr 2013
    upwey vic
    Thumbs up
    Just for future reference how many people make them and who's the best quality ? Or can you rebuild them?
    I thought it was OEM. I'm not sure if it can be identified by looking at it. The new one is Airtex (made in Spain). I hope it's a good brand.
    Oct 2007
    Williamstown, Victoria
    Ron, did you have much warning in the way of belt squealing or did it just go all of a sudden?
    No warning at all. Ditto when I had a similar failure previously. In that instance, I'd been to the markets, was on my way home when the pump failed as I crossed Victoria Bridge in Penrith
    I had to keep going to get off the bridge. Those of you who know the old bridge at Penrith know what a disruption I'd have caused if I'd stopped on the bridge!
    (Not my pic)
