11th May 2013, 06:52 PM
electrical problem
Hi guys, have been experiencing a problem with power to the radio. If the radio is on and I use the indicators or use reverse the radio will stop. Have checked the connection and all is good. I have not got a wiring diagram in my manual so have no idea where the power to the radio is comming from but I am guessing its from the same supply as the indictors and reverse light.
Any ideas where to go to fix this issue.
2002, defender 110
11th May 2013, 07:07 PM
I doubt it's a common supply as it's fused separately, more likely an earth fault, just need to find the earth point that they use an give it a clean.
11th May 2013, 07:16 PM
Thanks so much for that reply. Just kicking myself for not realising it myself. Sometimes we miss the obvious. Thanks again
11th May 2013, 08:44 PM
#4
Damn, my my03 has been doing this too. If you find the earth point could you update the forum?
