Results 1 to 8 of 8
Thread: D2 landbrake adjustment.
    Williams West Aust
    I need to adjust my landbrake in the D2 whilst doing this brake overhaul.It was all renewed 18months/10000ks ago so mechanically it should be good.
    I cant get my RAVE disc to load.
    How does one adjust it,what looks to be a Series Landy style S cam on the back of the drum or is there adjustment on the handbrake lever????
    Andrew
    DISCOVERY IS TO BE DISOWNED
    Snow White MY14 TDV6 D4
    Vendor
    Subscriber
    Jul 2012
    Tecoma Vic
    Cam at back off drum. tighten from outside
    Mario
    Jun 2010
    Bayswater, Western Australia
    Adjustment is both at the drum and at the handbrake cable:
    Feb 2011
    Brunswick, Victoria
    Many people of discovered that the adjuster isn't where RAVE shows it to be. It's often on the underside of the transmission tunnel.
    Williams West Aust
    Mine was there.What a whore of a thing to adjust.Spanner wont go in there,deep socket is too long,normal socket too short.A uni-joint and normal socket just do the job,the uni is very restricted in its movement.
    Landbrake now fully deployed in 3 clicks
    Andrew
    Landbrake? Is that an anchor you throw out the back?
    Williams West Aust
    Landbrake.
    Its a genuine Land Rover handbrake modification that goes right back to the Series One.For proof of this one needs to watch "The Antichrist" in action in "The Gods Must Be Crazy"
    Andrew
    Jul 2010
    Hunter Valley NSW
    Once I was done with the adjustments and after a drive around, I got under the car to touch the brake drum to make sure its not getting hot. This will ensure the the shoes not dragging!
