I changed the injector loom about 18 months ago for an OEM one, you will get traces of oil in the red plug for a long time so if you don't want to change the main loom keep a regular eye on it and give it a clean with contact cleaner every now and then (I started once every couple of weeks). It took so long to clear I thought the new loom was leaking as well but having checked the connector at the cylinder head it's not.
Something else to have a look at on that year is the fuel regulator. Have a look at your starter motor, if there's any trace of diesel chances are it's your regulator which sits just above it, mine leaked for awhile but I never noticed as the acoustic cover on the bottom of the engine soaked it up (cover is now in the bin!)
