Results 1 to 10 of 16
Thread: Handheld UHF selection criteria
    Oct 2007
    Wantabadgery, N.S.W.
    Greetings all, I'm looking to replace about six very old uhf handhelds. Most are playing up now and some not working. They belong to a volunteer group i'm attached to. I'm thinking getting some from either china or hongkong, so am I right in thinking I need to look for 12.5MHz channel separation, UHF frequency capacity to cover from 476.4250 to 477.4125. Anything else? The little FDC jobbies from 409 shop
    1 x BLACK 5W UHF FDC CB RADIO FULL RANGE + Earpiece - 409SHOP LIMITED (HK) Radio Wholesale
    (which I have myself) seem to be along the lines of what I'm after. Don't need dual frequency, but do need user programmable, robust, good price and reliable.
    Don.
    Gosnells
    Being a card-carrying Luddite.... I would not recommend the Baofeng UV-5R for technical twits such as myself, simply on the basis of being difficult to program (even with the purchased -cloned-cable).
    - The savings I made in the purchase.... $56 or so, were well and truly eaten up in time wasted (and hair pulled out!) in getting it up and running.
    - I finished up by entering all 80 UHF channels manually.....
    The WOUXAN seems to be better supported here.
    Anyway, the one in your link is only 40 channels. Why not go for the full 80 ?
    Quote Originally Posted by superquag View Post
    They can be programmed fpr 80 channels if you buy the software and cable for a few extra dollars.
    Oct 2007
    I found the FDC radios actually have 99 channel capacity and so I programmed the 80 channels myself manually. There is a handy feature in them where you can set the first channel then each other in 12.5MHz steps.
    Don.
    Oct 2007
    Can anyone confirm these ones are ok to use here in Oz?
    4 UHF Transceiver Australia 80CH CB 2 WAY Radio 5W Walkie Talkie Free Headsets | eBay
    Don
    Feb 2005
    i would go the one in your first link.......providing it the same freq as our 40Ch
    wouldn't be too bothered with the 80Ch units.....i reckon my existing 40CH is going to be around for 10 years plus therefore when i'm travelling with others the extra 40ch on their 80Ch unit are of not much use
    i'm yet to have a problem finding a ch on my 40 when touring
    Oct 2007
    When I got my GME (truck)unit upgraded to 80 channels, the technician at GME told me the transition period for the changeover was 5 years. I don't know what will happen at the 5 year mark, but I was left in no doubt that new purchases should be 80 channel.
    What I want confirmed is exactly what makes a particular radio suitable for use in Australia with our 80 channel system.
    Don
    Feb 2013
    Advice on UHF handheld
    I am in the market for a couple of handheld units to share with my brother-in-law and we are out with families and need to communicate between vehicles, while we are bushwalking and also to use to communicate with other 4wd around the area in case of distress.
    I have seen Uniden, ICOM, GME and Jaycar version(5W 80 Channel UHF Transceiver - Jaycar Electronics)
    I am no expert in Communications so I would appreciate some advice please.
    Any recommendations?
    Oct 2007
    ProjectDirector,
    I'm leaning towards these:
    Reasons being, a good price, easily available spares and accessories, they're robust (military spec chassis etc) They can easily be programmed with aussi 80 channels, I've already got a couple and they've been good, and nobody has come up with a better suggestion considering for my current requirements, I don't need dual frequency.
    Don.
    Feb 2013
    Quote Originally Posted by nod 130 View Post
    ProjectDirector,
    Don.
    I guess for $70 is not a lot to lose. I will consider this but I dont generally buy things from web, got stung once with credit card and not too comfortable doing this. Thanks for the recommendation.
