Results 1 to 10 of 15
Thread: Taps and Dies for Series 3 restoration
    Mar 2013
    Can anyone tell me what tap and die thread sizes (main ones) I will need for a Series three? Any comments on types (carbon steel/tungsten etc etc.) of taps/dies would also be very useful.
    We have just got the new Series 3 project into the garage this week and my boys and me have been stripping it down in earnest. The only stuck bolt I have encountered is the offside top hinge, might have to come back to that as its a tricky one being philips head, you cant get any power behind it.
    Shaun (dad to swaggy-with-a-landy)
    Narre Warren South
    Mostly UNF and UNC for a Series III.
    I do remember a few BSF on the transfer box, maybe it was the transmission brake.
    Carbon steel is OK for cleaning up existing threads, HSS better for cutting new threads.
    Colin
    '65 Series IIa Dormobile
    '70 SIIa GS
    '76 SIII 88" (Isuzu C240)
    '81 SIII FFR
    '95 Defender Tanami
    Motorcycles :-
    Oct 2003
    Godwin Beach Qld
    G'day Shaunmax
    I think that you will find that the front steering assy as well as the gearbox/transferis still BSF/Whitworth,the rest is a combination of UNF and UNC with a little Metric thrown in if it is a late Series 3, if it was an Australian Assembly (Pressed Metal Corp) they used what was in stock
    When disassembling box/zip bag and label everything, not bagging and marking is what leads to failed restorations.
    Mar 2013
    Quote Originally Posted by gromit View Post
    Colin
    Cheers Colin. I'll plan to get myself a set in the week. Haven't had to use the grinder to deal with any seized bolts yet - which is good as I haven't yet bought a grinder...
    Mar 2013
    Quote Originally Posted by UncleHo View Post
    G'day Shaunmax
    Cheers Uncle Ho. Have found a couple of odd sizes already - but we have bagged everything so far.
    How can you identify if it was Australian Assembly / Pressed Metal Corp?
    Brisbane, Inner East.
    BSW and BSF, UNC and UNF, some BSP, maybe NPT somewhere. BA on electrical and instruments.
    Chrome/tungsten/carbon steel taps and dies are useful for cleaning threads and cutting new threads by hand on soft materials like mild steel, grey iron, brasses, soft aluminium. For high grade steels and irons, heat treated aluminiums, titanium, machine tapping, and so on, use high speed steel taps and dies.
    You will rarely use anything over 1/2" on light automotive work. Sets are false economy for the hobbyist or home mechanic. At least one third will never be used.
    Start with an intermediate tap in sizes 1/4" to 1/2" by sixteenths. When buying dies, ensure they are split adjustable. If you can find a supplier who still has 1 1/2" dies in small sizes 1/2" and below, buy them in preference to 1" dies.
    BA taps and dies are available from Bruce Gardner B.S.F Bolts, 0408 056 255.
    I am out of the business as of end of last April and am currently in the USA so can not help.
    URSUSMAJOR
    Quote Originally Posted by shaunmax View Post
    PMC vehicles would have had a small alloy plate somewhere - but it may have gone missing! If the chassis number is on the LH rear spring hanger there is a good chance it is - home market ones had it on the front dumb iron I think.
    Situation is pretty much as Gromit said, but add the fact that most parts are interchangeable with earlier or later models and that it is at least thirty years old.
    For Series 3 most of the vehicle will be UNF/UNC, but there will be some parts still BSF/BSW a very few BA, and a few, increasing with later models, metric. But with interchangeable parts there is no way to be sure which particular bits will be what. (except for a few that stayed the same throughout Series production, such as drive flange studs which remained BSF).
    Queensland
    Get an impact screwdriver. The one you hit with a hammer. It will move the phillips on the hinge and is also invaluable for removing the slotted countersunk screws on the brake drums.
    Oct 2003
    Godwin Beach Qld
    YUP !!! I will second that,"Trade Tools Direct" are your friend.
    There should be a small metal plate screwed /riveted to the inside of the firewall just above the gear lever it will have the body number stamped/etched into it. something like 109. 126514 or similar that will be the PMC (Pressed Metal Corporation) Leyland Aust. Assembly Plant Enfield Sydney.
    Mar 2013
    Quote Originally Posted by 123rover50 View Post
    i knew there was something I could use, been a while since i messed around with old cars, the last was a 67 MGB. the landies not the only thing thats a bit rusty..
