Results 1 to 3 of 3
Thread: Defender vent seals
    Jul 2011
    Logan
    Defender vent seals
    Hi all.
    Looking at replacing the vent seals . What is the best option out there, the foam style that sticks to the flap itself, or the type that glues onto the firewall. It's a 97 110
    Thanks in advance
    Landiematt.
    Aug 2012
    Logan,Queensland
    I replaced mine with the SIII type that get glued to the firewall.
    These are rubber and should last longer.
    Although there is an increased chance of rusting due to retaining moisture behind the seal.
    The other type are just foam and would have a limited life especially if buying aftermarket, unknown quality.
    '95 Defender 130 Single Cab
    HS2.8 TGV Powered
    98% of all Land Rovers built are still on the road.
    The other 2% made it home.
    Cost difference between Britpart and Genuine seals: £2.04. Knowing that your brakes won't fail at any moment: Priceless.
    Feb 2010
    Deloraine, TAS
    I did the traditional foam on the vent falp about 12 months ago. Seems to have held up ok - though now that I said that I havent checked their condition for a while, but it continues to stop a significant amount of rain coming in so must be ok.
    Simon
    95 Defender HCPU 130
