Results 1 to 10 of 19
Thread: HF Radios and antennas - need advice please
    Aug 2010
    Sunbury, VIC
    So, I need a bit of help here. I know almost nothing about radios, apart from how to use my UHF to talk to someone else in a group of vehicles. HF radio seems to be a whole different ball game.
    I have a Barrett 550 HF radio that I will end up using at some stage. I know I need a licence, etc, but how to get the best out of this unit is a bit of a mystery to me. For a start - although a bit old, is this a reasonable unit? The bit of googling I did suggested it is still ok?
    It has an antenna, but not like what I have seen on other HF setups. I have seen those big based antennas on most setups and mine doesn't have that. Maybe someone can fill me on on what they are and what an 'auto tune' antenna is, and if I need one, and what the 'tune' button on the radio does?
    I know I need to subscibe to someone like VKS 737 or similar, but beyond that I'm a bit lost. I have no urgent need for any of this at the moment, as I'm not planning a trip in the short term, but I want to be up to speed by the time I next venture out where I may need it.
    The unit seems to work ok with the play I had with it yesterday - just listening in on various channels but I'm not sure if I need to do anything with the antenna I have?
    So, any information about the setup and use of an HF radio would be greatly appreciated. Start simple here please - this is a completly unknown world to me.
    Cheers - Gav
    in the wild New England, NSW
    OK - starting simple
    Take a look at VKS737: The Australian HF Radio & Radio-Telephone Network ! - once you join one of the providers you effectively become a joint licencee so there is no need to "get a licence". Sort of like joining an internet provider - gives you access to the system allowing you to transmit on a number of defined frequencies (which are probably in your radio).
    There is a bit of jargon and protocol but it should be outlined on the website and it's mostly fairly simple.
    If you have a tapped antenna (one with multi access points for the plug of a "wander wire") you don't need one of the large based aerials which are quite expensive. You manually change the frequency on the aerial to the one which you want to use. When the auto type is working correctly it "automatically" tunes to the frequency you are transmitting on.
    Does your antenna have a base, and does it have any maker's name or model on it ?
    Earthing the antenna base to the vehicle is quite important.
    The power supply to the radio needs to be adequate - the power drain when actually transmitting is quite high.
    Aug 2010
    Sunbury, VIC
    Ahh - the antenna makes a bit more sense now - it is tapped type, but I couldn't figure out how it worked, or which tap to use. I'll have a look at the base tonight and see what says. The power supply is good and solid - it runs through some huge cable straight from the battery through a fuse and to the unit - which is mounted right next to the battery box, so a short run.
    I'll have a look through the VKS website now so my future questions will be a little more informed.
    EDIT - Just had a google and I think my antenna looks very much like this - Barrett communications: 914 which make sense as the radio is a Barrett unit. I didn't see any markings on mine for the frequencies, but I'll check tonight.
    Cheers - Gav
    What vehicle are you going to use it on? The interference from EFI engines plays havoc. Just use it once camped.
    We need more details of the aerial. Or a pic. It's important that the frequency on the aerial matches that of the unit. You either jump out & do it manually, or via the autotune with a button press. The manual items are more robust & more efficient.
    These things have the wavelength of a football field, and are only about 1% efficient. So, they blast out at 100 watts.
    It's worth reading up on how they work, bouncing off the ionosphere etc. " The higher the sun the higher the frequency"
    The older units work just as well. Or better. They're more repairable too. Mine's older, its a Barrett 250.
    And as suggested, poke around VKS 737. Or one of the competitors. They'll issue you with a callsign.
    Have fun!
    Max P
    Aug 2010
    Sunbury, VIC
    It is set up in the back of the vehicle, so wouldn't/couldn't be used while moving.
    Just been going through the VKS website - plenty of useful information, but one thing that I found was they make the times for thier daily radio skeds known only to members. While I can sort of understand that, it makes it hard for a newby like me to know when to listen in to see how it all works.
    If it's not a closely guarded secret, can anyone tell me when the skeds are for the different frequencies?
    I would like to listen in and see what it is all about...
    Cheers - Gav
    sent you a pm...
    Aug 2010
    Sunbury, VIC
    Thanks for the email
    Now, I have some more detail on the antenna and a few questions. I think the antenna is a Barrett, but not sure of the model, as the current manual tap antenna on their website say it has 12 taps, but mine has 20...? It is 6' tall. Looks like this... There are no readable model numbers on the sticker at the bottom as it all has a coat of olive drab paint...
    Sorry for the photo on its side, I couldn't fit it in otherwise.
    Now for some questions on the markings. Some I think I can work out, but others I can't. From the bottom of the antenna, the taps are labeled like this...
    The very bottom tap which is on its own by a fair way I am assuming is the fixed common point? It has 2 labels. One says '2020' and the other says 'WL-150'. The taps up from that read
    RT12
    VKS5
    4980
    RT13
    5300/60
    VKS1
    RT22
    6790/6845
    RT14
    7465
    7899
    VKS2
    RT23
    RT15
    RT16/19
    VKS3/RT2
    RT24
    VKS4
    RT17/19/21/25
    I am assuming that the VKS ones match the frequencies of the VKS channels? The 4 digit numbers are other frequencies? No idea what the RT ones are.
    Can anyone confirm that the bottom tap if the fixed tap, or does it work different to that?
    Cheers - Gav
    Quote Originally Posted by bacicat View Post
    Yes , that's correct, fit one end of your wander wire to that and the other end to the upper tap that you want to use ..... mainly needed on transmit
    Adelaide SA
    2020 is an RFDS Channel
    RT12
    VKS5
    4980 RFDS
    RT13
    5300/60 RFDS
    VKS1
    RT22
    6790/6845 RFDS (I think)
    RT14
    7465 RFDS
    7899 RFDS (I think)
    VKS2
    RT23
    RT15
    RT16/19
    VKS3/RT2
    RT24
    VKS4
    RT17/19/21/25
    Cheers - Gav
    Have a look above. Going by memory from a LOOOONNNNGGGGG time ago, when I built HF radios for Tracker Communications
    The RFDS channels are good to listen into, especially if the School of the Air is operational. Do they still use HF??
    The way we used to build them, the lower the frequency, ie: 2020, the lower the channel number, ie: chan 1. 4080 on chan 2 etc...
    Disclaimer - this was back in the day when we used HAND CUT crystals in the radios. And they worked really bloody well. Adelaide to Brisbane no problems...
    Aug 2010
    Sunbury, VIC
    Quote Originally Posted by Basil135 View Post
    Any idea about the RT taps? Can't find anything that shows what frequency these are.
