Thread: 186 compression psi??
    Jun 2010
    VIC
    Hi, Just got a SWB 2A with a 186 in it. It seems to have a lot of crank case pressure, oil out the dipstick, puffing out of the pcv hole if i pull the pcv hose out.
    But.... It has about 140psi after a compression test and I thought that was ok but maybe not?
    The PCV valve and hose are fine so I think it might be blowby.
    And it does seem very low on power.
    So do you think I'm up for a rebuild?
    Anyone done one lately and know the cost of machining.
    I would do the spanner work.
    Seaforth NSW
    Hi,
    Did you wash the PCV in petrol to clean it? It's a spring loaded valve so may be gummed up. Had to replace one once in a 186. Check the hose too for blockage.
    Hope this is of some use.
    Would think you would see 135-160psi at least compression in a 186 with only a variation of 5 or so psi.
    Bob
    Last edited by bobslandies; 23rd May 2013 at 07:11 PM. Reason: Added the compression test expected pressure
    Hay Point
    pretty sure (from memory) forgive me if I am wrong, the figure is 165psi with 10 percent variance between cylinders.
    Cheers......Brian
    1985 110 V8 County
    Jun 2010
    VIC
    PCV seems fine, it rattles and he hose is clear.
    Maybe it's just a shaged engine
    Seaforth NSW
    Quote Originally Posted by Bearman View Post
    Hi Brian,
    My uncle used to marinise engines for GMH and rebuild Holden sixes and he tried to get a lesser variance between the cylinders so I remembered that. I rang him and he said that you are right - a 10% variation is ok. 165psi in a 9.2:1 186 would be a good engine, getting close to that on all cylinders would be ideal.
    Bob
