Results 1 to 10 of 16
Thread: leveling a defender puma
    Jul 2007
    Brisbane North
    I want to level out the front of my 110.
    With my TD5 the thing to do was fit 130 front springs. Is this still the case?
    With the slight lift would I need to fit a double cardan joint?
    Feb 2010
    Sutherland Shire, Sydney
    I had genuine Land Rover HD springs fitted to the front of my puma to handle the 140Kg weight of the bull bar and winch. Since they are genuine springs factory designed for the vehicle there was no need for a double cardan joint.
    Jul 2011
    Yarrawonga, Vic
    no, Td5 110 propshaft is good for up to 2" lift,
    its only the Pumas that run into trouble when you lift them because the motor/gbox/tcase is all on uphill and canted over angle
    any lift on a puma and you run into trouble
    that said I had 130 front springs on mine (with bar and winch) and found it too stiff. King standards are just right (for me)
    Jul 2007
    Brisbane North
    That's what concerns me. From my understanding the front of most Pumas aren't sagged its just how they come. So when I fit new springs its going to raise the front 1-2 inches.
    Jul 2011
    Hi Aaron,
    Sorry to off the topic of this thread, I happened to come across another thread you posted regarding greasing the propshaft. Have you found the grease nipples for sliding splines? I can't find them on my 2.4 puma.
    Thanks.
    Wei
    Jul 2007
    Brisbane North
    That would have been me posting with my old TD5.
    Are you talking about the nipple on the shaft itself?
    Jul 2007
    Brisbane North
    Give this a crack! Hope you get greasy nipples soon.
    Just "Defender" or bad quality?
    Jul 2011
    Quote Originally Posted by Aaron View Post
    Oh, I thought you were talking about 2012 puma defender. Just re-read the post, it was a 02 one.
    yup, I suppose there's a nipple(other than the 2 in u-joints) for greasing the sliding splines on each shaft, but can't find it.
    Adelaide - Torrens Park
    Quote Originally Posted by labrado View Post
    There might be a small bolt in the nipple hole. Remove the bolt and fit a nipple, then grease to your hearts content.
    Qld.
    I've just had King springs (one of the 110 types) fitted to my 07 Aaron....there are actually 3 or so different "standard" King 110 springs which are for different loads.....MR fitted ones to my Puma that were suitable given my vehicle, which has a bullbar (no winch) and full drawers, long range tank, 70 litre water storage etc etc.
    Grover now sits up much nicer than it did before, although my original springs had sagged so it was difficult to say how much higher it is than standard...but it is definitely higher and is very noticeable getting in and out of the vehicle.
    I have had no dramas even though it's effectively got a lift. No double cardan joint required for mine.
    Ring MR and talk to them about what they did to mine....will likely work for yours.
    2007 Defender 110
    1993 BMW R100LT
