No you can't use your winch extension strap as a snatch strap. It is the elastic stretch of the snatch strap that build kinetic energy and pulls the car out with more force than towing alone. Also they is less shock loading as it stretches gradually before the energy is released.
You could use the extension strap as a tow strap and pull a car out that is not stuck hard and just needs a bit of a pull. But bring on the power gradually, not fast. You can also use an extension strap with a snatch strap if you need extra length.
				Cheers, David.
My Land Rover has made me a better Mechanic........
D2 TD5 Manual, CDL, Detroit Rear, Truetac Front, 2" OME lift, 32" MT Tyres, ARB Bull Bar, Winch, TJM Roof Rack,  Driving Lights, Dual Batteries, ARB Side Steps, Rear Draws, Uhf.
