Results 1 to 4 of 4
Thread: Fixing fuel tanks
    May 2013
    queensland
    Fixing fuel tanks
    I have been reading about fixing petrol tanks and thought someone might have experienced this before.
    Red Kote seems to work but i read that using a mixture of Plumbers glue and cleaner also works a treat.( last 20 years so the chap explains )
    This interests me because i use it at work regulary and i know it does form a skin inside the bottles and i suppose this is what you are looking for inside the fuel tank.
    So if anyone has used this method it would be good to get some feedback.
    Thanking you perry.
    Narre Warren South
    If you use the search function you will find what you need.
    here's some info I posted when I did my tank.
    1956 Series 1 with PTO welder (home made)
    Post #36
    Colin
    '65 Series IIa Dormobile
    '70 SIIa GS
    '76 SIII 88" (Isuzu C240)
    '81 SIII FFR
    '95 Defender Tanami
    Motorcycles :-
    Narrogin WA
    I have used Back In's glue method - works really well. Clean the tank with caustic soda first,
    Cheers Charlie
    It works
    Hi All
    pleased to see my ideas do work
    Just one thing
    water it down with a little more primer
    helps in spreading the mix over all the surface
    keep moving the mix around coating top and bottom
    until it skins
    Ian
