Thread: winch cable power leads how long
    Mar 2007
    byford
    hi guys I am fitting a winch to my puma but I know the cables have to be longer then nomal. how long do they need to be?
    2stroke Guest
    Long enough to reach from the battery to the solenoids. You have a tape right?
    Nov 2012
    Jandakot, Western Australia
    I am actually in the process of doing exactly the same thing myself, by my measurements I reckon the cables need to be extended by about 1500mm to allow for following the body shape etc... I've mounted the control box in the drivers side guard and the existing cables extend to about n the corner of the windscreen on the drivers side. I'm looking at maybe mounting an isolation switch in the dash on that angled plastic bit to the right hand side of the main metal part of the dash.
    2stroke Guest
    Sorry Beefy, just couldn't help myself. I assume you mean the heavier power cables?
    Jan 2008
    I think to memory I got 3m and it just made it by a few 1nches
    Given the $18 per meter I paid it would be wise to have a dry run with some twin and earth or soenething similar and add a wee bit
    Defender 90 - WEE 90
    172-562 2a Workshop - Tassie Devil
    REMLR 331
    Quote Originally Posted by Garry View Post
    I too used 3m & it juuuuuuuuust made it.
    If I was starting again I'd go 3.5m to be more comfortable.
    '51 Series 1 80"
    '12 Defender 90
    Feb 2010
    Townsville
    I would personally run my main power cable of the starter motor I have not had any trouble in my two trucks, if you don't want to have a control box put a Albright on and run 3 wires to the dash
