The term layer refers to the layers on cable on the drum. If the cable is all the way out you are on the first layer. As it rolls in and the cable rolls back over it's self then that's the second layer ect.
As the cable layers go up the gearing ratio is changed as the drum is now a larger diameter.
				Cheers, David.
My Land Rover has made me a better Mechanic........
D2 TD5 Manual, CDL, Detroit Rear, Truetac Front, 2" OME lift, 32" MT Tyres, ARB Bull Bar, Winch, TJM Roof Rack,  Driving Lights, Dual Batteries, ARB Side Steps, Rear Draws, Uhf.
