Thread: Electronics under passenger seat
    Sussex Inlet. N.S.W.
    Can anyone tell me what the box under the passenger seat does? Vehicle is an '03 TD6. Thanks, Jim
    Jim VK2MAD
    '17 Isuzu D-Max
    Mar 2007
    Jim
    If it's the one with a cover, it's the BCU (Body Control Unit)
    Laurie
    May 2010
    Jim, Tilt sensor is also there, and if you have the Tyre Pressure Monitoring kit fitted its ECU is below the Body Control Unit also.
    What on earth does the body control unit do?
    Jim VK2MAD
    '17 Isuzu D-Max
    Aug 2010
    Sunbury, VIC
    All sorts - don't drown it, or you'll find out exactly what it does...
    Mar 2007
    Jim
    Basically it's the central brain for the electronic systems in the car, the engine has it's own unit ! The amount of functions it performs varies from model to model, but usally it's in line with the options fitted.
    Laurie
    May 2010
    FYI...BCU box info from the manual....
    http://rapidshare.com/files/14712719...0(dragged).pdf
