Results 1 to 10 of 35
Thread: 200Tdi - Rebuilt - Where to source
    ashhhhh Guest
    Hey all,
    It looks like my 200Tdi-->Series 3 109 conversion is a goer, I just need to source the motor.
    Can anyone suggest a good supplier?
    Im after a good low km example (hopeful I know..) or a fully rebuilt item.
    I would prefer the Deefer engine.
    Ash
    Narre Warren South
    '65 Series IIa Dormobile
    '70 SIIa GS
    '76 SIII 88" (Isuzu C240)
    '81 SIII FFR
    '95 Defender Tanami
    Motorcycles :-
    WA
    Why not a 300tdi??? They will bolt in almost as easily as a 200, and are much easier to get hold of locally.
    Plus the disco version does not have the turbo in the wrong spot like the 200 does.
    Narre Warren South
    '70 SIIa GS
    '81 SIII FFR
    '95 Defender Tanami
    Motorcycles :-
    ashhhhh Guest
    Cheers.
    Yeah that import place want 6k, landed..
    Tried them a while back.
    Ahh the 300 takes enough extra work that it doesn't interest me. (moving engine mounts etc)
    I'm also keeping the stock gearbox so dont need any power above what the 200 will output.
    Yeah Gromit ive seen a few whole vehicles around, its the transport that's the killer.
    Also, im a bit suss on "rebuilt" engines.
    I would rather a low km version which has not been rebuilt, or a freshly reconditioned item.
    WA
    Quote Originally Posted by ashhhhh View Post
    200 and 300 are both 111 bhp in disco form. I believe the defender version of the 200 was detuned. It would be a 5 minute job to do the same to a 300 if you were concerned.
    You can leave the chassis mounts as-is easily enogh if that is your concern.
    ashhhhh Guest
    So how do you fit it and retain the existing mounts?
    Every conversion ive read involved them cutting and re-welding the mounts, this immediately adds a "check point" when the engineer has a look.
    WA
    The LHS of a 300 tdi block still has the boss and even the stud holes for the 200/series engine mount.
    Not sure about the RHS, but it would be easy to make a suitable engine mount, to avoid modifying the chassis.
    ashhhhh Guest
    So have you done the conversion before yourself?
    If not, is there someone who can confirm 100% that stock mounts can be used with a 300tdi?
    Already I am finding a ton of information, lots of it conflicting..
    Im happy to fab some new mounts if required, just be good to know beforehand.
    Basically this is my only vehicle and im not keen for it to be off the road for months while I work through 500 unforeseen problems.
    I want to know exactly what is required ahead of time, so I can have all parts on hand. (probably deluding myself by saying "all", "most" might be more realistic..haha)
    WA
    No, I have not done it, but I own a 300Tdi disco and a IIA with a 2.25D which I am converting to DI using 300 tdi parts.
    I can double check the mounts tonight between the two motors.
