Results 1 to 6 of 6
Thread: defender alloys on campertrailer
    Mar 2009
    maryborough qld
    Has anyone put alloys on a campertrailer with 10" drums?
    Jul 2011
    Yarrawonga, Vic
    No but if its any help I have Defender 130 rims with 12" Drums & 2000kg stubs/bearings on my off road caravan,
    Holroyd Goad make them
    Holroyd Goad
    the bearings are massive compared to regular trailer / caravan bearings
    the studs are plenty long enough for alloys but you would need to source nuts to suit.
    May 2011
    Adelaide
    Hi
    I have a set of 10 rangie classic wheel studs to sell if that's any help.
    Steve
    Adelaide Hills - SA
    Make sure you get some proper advice on this.
    On an alloy, the wheel nuts are just there to stop the wheel falling off. They do not take any weight.
    The weight is borne by a ridge on the hub that mates up to the big central hole in the alloy (does that make sense?).
    I tried to get some hubs manufactured for my trailer so I could use my defender alloys, but couldn't find anyone to do this properly.
    In the end I went Land Cruiser wheels because the hubs were available off the shelf
    Nov 2011
    altona
    alloys
    I worked at sunshine trailers in vic for a while. We would not fit alloys to camper trailers for same reason as above
    St Helena,Melbourne
    4.28 MB
    Not sure about alloy rims but i have ford transit hubs which are the same PCD and they have the step that my steel disco rims fit snuggly on.
    Studs need to be replaced with landy ones but otherwise they work well.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
