Raise the car as high as possible and then jack - saves a lot of jacking. If you lower to access height you will have a lot, lot, lot of jacking to do.
Locking at access height may stop height movements when driving slowly but does not actually lock the suspension as such. Jacking from that position means the body will go up and up using up all the downward travel of the suspension before the wheel lifts off.
