Results 1 to 3 of 3
Thread: Jack / axle stands
    Shepparton
    Jack / axle stands
    What would you consider as the minimum rating for jack stands for a Disco?
    When it comes to this sort of thing I like to over do it. I have a set rated at 4000kgs and another at 2000kg which should be more than enough.
    Working it out in my mind I would estimate the disco at 4000kgs, the max load at each corner if equally distributed would be 1000kgs. Allowing a bit of safety margin I would look at 1500kg as minimum rating.
    Aug 2009
    Brisbane, Sunshine Coast, Gladstone, QLD
    Quote Originally Posted by crash View Post
    The disco will weigh less than 3000kg as the GVM is less than that, so unless overloaded etc, but I would empty the vehicle before lifting it anyway.
    In regards to the actual rating of axle stands, I would go for the highest rated ones you can, I will get a new set of 5000kg rated ones prior to pulling out the suspension to repalce all the bushes.
    My reasoning is;
    • Higher rating
    • Larger base plate area
    • More stable
    • Lift higher
    Aug 2010
    Sunbury, VIC
    I would buy the biggest you can afford for a few reasons. You will get more lift, larger safety factor and a larger base. You will appreciate the larger base when you are under the car wrestling something heavy or leaning hard on a breaker bar undoing something.
    I have some big old truck stands I picked up from a garage sale years ago. They have a large cast base and screw adjustment. They are rated at 7,500 Lb (about 3,400Kg) each, so they keep any of my cars off the ground easily and safely.
