Results 1 to 3 of 3
Thread: ABS Modulator 12 pin vs 13 pin
    May 2010
    Mindarie, Western Australia
    Im in the process of changing my ABS Modulator on a 1996 HSE. I recently aquired a 1998 model in the belief that they are the same unit (ie GEMS prior to the Bosch 4 wheel traction control) but that appears to be not quite the case. My original 1996 unit has a 12 pin connector whereas the 1998 one has a 13 pin connector. (No pin number 3 on the 1996 unit) The plug on the wiring harness fits and even has a hole for the additional pin. I've had a look through the RAVE manual and do not see a change to the pin configuration on a 1998 ABS Modulator, only post 1999 do I see that the 12 wires go to different locations on the ABS ECU.
    Before I reconnect the battery, has anyone else stuck this before? I have installed the unit and am ready to go through the brake bleeding process.
    Gary
    Ben980 Guest
    Hi Gary
    Did you have any luck getting it to work?
    Ben
    May 2010
    Installed with no errors. Relieved and delighted with the result!
    Gary
