Thread: 2.6 F-head problems
    Jan 2012
    Port Macquarie
    2.6 F-head problems
    Alright so i have just put a vrs kit through my 2.6 f head and it still miss fires on 3 cylinders, it had a blown head gasket, all the valves were good and i have reset all the valve clearances. has all good compression and its has a stromberg carby on it and im pretty sure its overfueling like crazy, i am thinking of making an adapter plate for a down draft carby. and ideas why its missing? not firing at all on 3 cylinders!
    Nov 2011
    Leads, dizzy top, rotor, plugs - would be the first things I'd be checking
    Jan 2012
    Port Macquarie
    cheers!! yeah feeling it might be plugs i just replaced the rotor button and i am gunna try a dizzy cap i have with the leads built into it sarvo, see if that works might find some plugs and try them too!
    Narrogin WA
    Quote Originally Posted by SMASH View Post
    ci just replaced the rotor button and i am gunna try a dizzy cap i have with the leads built into it sarvo, see if that works might find some plugs and try them too!
    What make of rotor arm is it? There are heaps of new crappo rotor arms available now, which don't work! Try using your old one if you suspect this is the problem, or buy one from the Distributor Doctor in the UK.
    Use NGK plugs and good quality leads,
    Cheers Charlie
    Nov 2008
    seaham (gods country) nsw
    Hey
    My 2.6 needs plugs and leads replaced every 15-20000 km otherwise it gets a terrible miss. I only use NGK plugs, topgun leads and bosch dissy gear.
    usually carry a spare rotor as well.
    Tangus
    1925 - Trojan Utility
    1973 - jaguar XJ6
    1980 - Series 3 FFR
    1980 - Series 3 GS
    1998 - 300tdi 130
    Any sufficiently advanced technology is indistinguishable from magic. - Clarke's Third Law
    Melrose SA
    I have got a brand new carb for a 2.6 if you need one
    Jan 2012
    Port Macquarie
    thanks guys it was plugs and i reset all the exhaust valve clearances need to buy some new plugs i have some 2nd hand ones in it
    Cheers!!
    Jan 2012
    Port Macquarie
    Quote Originally Posted by djam1 View Post
    How much would you want for it? and is it a stromberg?
    Jan 2012
    Port Macquarie
    Anyone know the NGK code for the plugs?
    Nov 2008
    B5ES from memory
    Tangus
    1973 - jaguar XJ6
    1980 - Series 3 FFR
    1980 - Series 3 GS
    1998 - 300tdi 130
